SOLD FS: 2x Alpine MRP-M500 - $150 each / $250 BOTH
  • 6
sundownz
Pro Seller
Supporting Vendor
11,349
North Carolina
Shipped in Continental 48 states.
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.
NO TRADES - Do not PM me with "What is the lowest you will take" - MAKE AN OFFER if you have one.
# mono subwoofer car amplifier
# 300 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
# variable low-pass filter (50-200 Hz, 24 dB/octave)
# variable bass boost (0-12 dB at 50 Hz)
# subsonic filter (15 Hz, 24 dB/octave)
# Class D amp with MOSFET power supply
# CEA-2006 compliant
# STAR Topology (minimizes internal noise and prevents ground interference)
# speaker- and preamp-level inputs
# gold-plated screw terminals
# fuse rating: 30A x 2
# 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
# 10-11/16"W x 2-7/16"H x 9-9/16"D
ONE AMPLIFIER HAD THE MOUNTING FEET REPAIRED. You cannot see this once the top covers are mounted.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
482
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
697
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
bw_audio
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
