Help With Acoustics in my design
  • 1
bbbblaah
Hey all,
New here just trying to get some help. I am workin on a fully custom fiberglassed sound system for my extended cab 95 nissan minitruck. Right now I have 2 10s that I am building a box for behind the front seats. I have the back fully open for the entire space to be used. I know the general size of the enclosure for my subs and I am designing around that.
First, I would like to know if the way I have them pointing is a good idea. They are angled (or will be) so that they point in the relative direction of a driver/passengers outside shoulder (towards the window). The Amp will be placed between them. I am thinking of putting 2ways beside the subs pointing towards the inside of the truck, but more upwards. How will this sound/is there a better way to angle them?
Thanks alot everyone, there are some great threads here!
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
86
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
588
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
579
bbbblaah
bbbblaah
Charlotte, NC
bbbblaah
