help please need advice abiut the base end of an sq... system
  • 1
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
984
Or you can buy a bypass https://lljcustoms.com/products/2018-2021-gm-gmc-factory-anc-bypass-select-vehicles
4
985
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
eric427
eric427
granburry texas
eric427
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
