Help on Subwoofer Set Up
  • 2
Well that was a quick response. Thanks alot man.
He said with the music I listen to I should go with a sealed box but from what I have been reading I was thinking the ported would be better as well.
Once again thanks
How you think the sub with that amp along with the stock BOSE will sound? Do You think it will sound like I have almost 2 12"'s? And i forgot to mention that I will also be dynamatting the whole trunk since I hate hearing trunks rattle with subs.
it is all dependant upon the installer who will be building your enclosure my freind. if he does well then it shall sound great im sure. the bose systems dont sound half bad so you should be confident that it will fit the bill!
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
819
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
7
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
BWareofDWare94
BWareofDWare94
Maryland
mr. man
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
