help a port noob
  • 1
Bobby322
TX
Alight I have 5.38 cubes after displacements other than port. Im using an 8'' port. I put 12.75'' of port inside the box and that leaves me right at 5 cubes after its displacement. I then have 7.8'' of port outside the box. I want to tune to 32hz and I think I have too much port on the outside. 12.75'' is my max inside so that I can have 8'' between bottom of box and port for it to vent. Any help? This is my first time building a box and using tube ports. I already have the port in, but I can cut it easy.
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
None so far, there was a factory 8 inch subwoofer that I took out for a pass through, I'm definitely going to have to get some sound deadening...
10
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
552
Bobby322
Bobby322
TX
Bobby322
Decebal
    Jun 10, 2024
