heat problems
  • 3
Depends on what type of amps these are. Lightining audio has changeable heat sinks that incorporate fans for cooling. Other than that Try mounting on board wil a lilttle elevation between tha amp and board.
Jordan
Heat is one of the worst enemies for audio equipment. I would play the amps for awhile and see how much heat they are giving off. Then i would decide if i want to ruine it with enclosing it. With mounting it fluse its basicaly puting a blanket it on it and the air flow is deminished. Depending on the load the amps are under will greatly determine the amount of heat. The more room the more air //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif If you can find a spot cut a hole and place vent cloth over it to allow air to flow, and the vent cloth makes it less noticable. Play around with idea's, installing fans will hardly make a dent on your current draw. And just a simple rocker switch is all you need. and a relay, all this info can be found on the net. The flush mount looks nice and if they over heat... whats the point? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Good Luck...
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
Are there any label making machines available that allow you to print directly on your currently owned heat shrink and not from a manufacturer...
Any air movement is helpful in keeping any amplifier running cooler as long as there is a way to release the heat build up. I install all my amps...
Upside down should be fine. Airflow is all that matters. My buddy did this install. I think 14 amps. Look at that sloppy wiring. 😂 Vegas don't play.
4
adriaen
adriaen
canada
Matt
chillin
    Jun 14, 2024
