headunit recommendations
  • 2
Rainelli
CView, FL
Im looking for a double din with bluetooth I've always gone with kenwood in the past but I've heard good things about pioneer
I was looking at the
kenwood ddx419
Pioneer-AVH-P2400BT
Pioneer-AVH-X3500BHS
Pioneer-AVH-X2500BT
Not sure witch one I've never had a pioneer but I've heard good things and bad things about em. But I've never had a problem with kenwood
Might want to check out the Sony 601 and 701 lines. Twistedchild is running one of them iirc. Apparently, Sony is starting to step up their HU game. I was messing with the 601 at Best Buy and it is quite a unit.
Pioneer is a great choice too, now that they are making DDins with 4v preouts.
I don't blame you being skeptical about Sony based on their other lines of stuff. But I wouldn't mention it if I thought it was going to be a POS. It has some really nice features and Sony is more than capable of producing an excellent receiver even after years of garbage.
Pioneer or Kenwood are great choices, there is also a Clarion DD that is supposed to be pretty nice. Idk how important having 4 volt or above preouts are to you. I'd just look at either of them for the features you want/need.
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
565
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Rainelli
Rainelli
CView, FL
E-Rock
