Headaches...parametric eq, double bass kick, bass guitar, sound processor ?
  • 1
Knight777
Ok, Well if someone has covered this before, which most likely has happened please inform me. I have recently spent about $1,300 on a car audio system. I purchased an Alpine cda-117, 2 kicker dc12's with an alpine mono block 500w rms amp. I already have 2 infinity 6X9's in the back. It is a toyota pickup with an extended cab. I listen to Rock Music. I believe the bass guitar and the bass drum double kick, are overlapping in the subs. I prefer a clean sound, and want the bass drum and guitar to be separate. Do I need to purchase some 10's and can I send just those frequency's to them? If so how do I go about sending just the bass drum or guitar to a particular set of speakers. Either the bass drum kick or the bass guitar or do they overlap ? Which brings me to another question. I have no problem operating a graphic equalizer, which the Alpine has a 7 band graphic EQ. I cannot solve my problem in the graphic EQ. If someone could tell me what frequency and bands on the parametric EQ I can quiet the bass guitar down, that would be beneficial. I've always been able to listen and use a graphic EQ, but the total control of the 5 band parametric EQ has me somewhat puzzled. I play with it, then the music sounds over-processed, but yet the Bass guitar and double bass kicks are still rumbling together. Anyways The speaker box is wired for 2 Ohms, hence there is only one speaker input. This is relatively new to me as the last time I had a decent stereo was about 10 years ago. I just need some advice. I'm to the point I want to take the whole system back. BestBuy's customer service blows. No one listens to rock anymore anyways.. Rap is so much easier to tune, so here to being synthetic
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
768
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
7
I’m at 3 yrs on my Tucson alternator. W the electrical challenges i faced it’s been worked hard. Thankfully those challenges have been overcome...
99
9K
Knight777
Knight777
Tuscaloosa, AL
Knight777
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
