Hdc3 18 Smaller box for more power?
Hmmm... I actually do have 15in per cube. So even with more power? I thought a box csn be smaller then norm with more power? Also it wasnt very much bigger before with smaller ports and way less power.
AQ is pretty stiff suspension and it's harder than you think to bottom out an 18" on a 6 spoke frame if you're not a total retard playing below tuning. I was running an 18" with 2 very soft TC 10" spiders for a little while in nearly 9 cube and didn't run into excursion issues... though the point is my bet would be you would gain more going to 6 cube than using that extra cube in port displacement.... just my experience..... 20" port per is nice, but not a deal breaker I think
What he said... Either build a burp box or a daily box, not both...
Actuay you can have both. I have a friend in meca and iasca that has a 6th order that has a bandwidth from like 30 up to 60 strong. But thats the box he uses for burps as well. Actually when your loud on music then you should be loud on a burp. That why i build for music
IMO if you want to play down to 28 you should tune @ 32. Tuning to 38 and trying to play 28 is asking for trouble on high power.
Im not a retard i dont try to play way below my tuning. I usually tune are 38hz i dont really listen to any thing below 35
That's not always true. Buck meters higher on music than he does on burps. It doesn't make much sense, but I was there when he metered... the termlab doesnt lie lol. Higher tuning and larger port area does better for burping and chasing numbers. If you want a good daily box it won't have quite as much port area and will be tuned a lot lower.
i know this from exp, when i ran this setup before i was .7 to a 1db lower on a burp, then when i played music. my burp on the dash was a 145.4. playing music i did 146.3
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
726
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
752
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
889
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
bgowdy
