Does adding volume to an enclosure change the tuning?
  • 4
Badfastbusa
Wheelie addict!!!
268
Atoka, OK
I have a fox acoustics ram quad cab box DODGE QUAD & CREW CAB 2-12" VENTED for 2 SA-12's, and I want to cut into the box and add more air space to it, if I cut into it and added .6 more cu/ft on each side of the box, would it change the tuning of the box? If so, what would it change the tuning to if the box is 1.55cu/ft per side tuned at 35hz right now, the displacement of the subs are 0.14 ft^3 each, and I wanted to add enough to each side to reach close to 2cu/ft on each side, or at least 1.75.
Basically, right now at 1.55cu/ft per side and subtracting the .14 displacement of the subs, that only leaves me with 1.41cu/ft per side which isn't enough and it isn't digging the lows like I want it to. It HAMMERS at around 40-45hz, but I like the lower bass. So I am wanting to add .6cu/ft to each side.
I have racked my brain and searched high and low to find this answer and can't figure it out. Thanks for the help.
Your tuning should drop with added volume, but you need to be sure to retain enough port area per cube net
Yes, adding volume will change the tuning. In this case, the tuning will be lower. But before you go to that much trouble, get some Acousta Stuff from Parts Express and put it in the box. It slows the movement of air inside the box, effectively making it perform like a larger enclosure.
If that doesn't work then get out the saw.
I'll try the fill and see how that does.
Hes not gonna get that much out of stuffing tho. stuffing ported boxes is meh anyway. OP whats your current port length
---------- Post added at 02:04 AM ---------- Previous post was at 02:03 AM ----------
and dimensions of the port opening
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
484
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
Badfastbusa
Wheelie addict!!!
Badfastbusa
Atoka, OK
SMS
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
