Hairtrick port area?
I would say a 1x15 inch port should get the job done, depending on the subs you use that is............//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
The larger the port the more air displaced. It will also have to be longer to get to a given tuning frequency. It is a trade off with space and displacement. Also, larger ports will have less port noise.
Or to be put simply: go a big as you can while keeping the desired net volume of the enclosure.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
787
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
965
942
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
murderedtahoe
Mr. Low End Monster!
murderedtahoe
GA,SC
audioholic
    May 31, 2024
    May 24, 2024
