Does not each individual stroke of the sub and consequently port air resemble and behave similarly to water through a hose?
Only to an extent. people love to use the water hose parallel, but air is compressable, water is not.
More friction is created by the added pressure of a smaller port than by the added contact area of a larger port.
Im sorry, but that's simply not true. Higher pressure does not equal greater friction, greater velocity across the surface DOES.
I didn't really think I was disagreeing, just pointing out that the root of it is friction, velocity is just part of the friction force equation
My point was you are arguing the opposite side of the same coin. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Friction does increase as velocity goes up. I said higher velocity causes the turbulence, you said it was friction. Answer is, its both. But within the context of this discussion, its more relevant to discuss air velocity, not simply friction. The topic was about port diameter, not necessarily how smooth or rounded the edges are.[
QUOTE=Rashaddd;5596095]If not for friction and the loss caused by it, what creates the difference in output between different sized ports? It can't be air velocity, if it is, then why isn't a smaller sub with more excursion inherently quieter than a bigger sub with less excursion (same displacement)?that's where you are misunderstanding, you assume a different sized port will automatically mean different output levels. Again, you can have a smaller port with increased air velocity inside it that will display the same over all air displacement as would a larger port that would inherently have lower air velogity within it. Now a port CAN become so small as to choke off the woofer and decrease its displacement capability, but that's not what Im referring to here. Assuming the port is within an acceptable size range, the woofer itselt will dictate the amount of air displaced through the port, not the port itself.
You read it wrong, I wasn't implying that turbulence/friction/port noise can't or isn't easily audible, and I wasn't implying that increasing port area and thereby decreasing air velocity wouldn't decrease its audibility. I was pointing out that the idea that "if i can't hear port noise there's no reason to increase port area" is invalid, unless port noise is your only concern regarding the system, obviously.
I understand your comment better now. I still dont fully agree however. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif If the port is of sufficient size that the amount of air displacing through it creates no audible port noise, turbulence is likely low enough that increasing port diameter wont help much. that may not be true for an SPL competitor trying to inch every tenth out of his system as he can, but for most of us, if it doesn't have audible port noise, you have plenty of port area. If you think your port is too small that it is choking off your sub's performance, it would have audible port noise. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Dont mean to sound argumentative Rashaddd, just trying to make sure everyone understands.
