eg9 10+ year member
Above^^^
Very clean, great sound but found another amp so don't need this one. Amp is in excellent/mint condition and works 100%. Definitely underrated RMS power ratings and great old school style SQ amp!
Specs:
-----------Soundstream Reference Series 4-Channel Class A/B Car Amplifier(4.400)
-RMS Power Rating:
4 ohms: 70 watts x 4 chan.
2 ohms: 100 watts x 4 chan.
Bridged, 4 ohms: 200 watts x 2 chan.
-MOSFET power supply
-RUBI (Rapid-Use Branched Impulse) proprietary power supply technology
-STACT (Stabilized Apex Current Technology) reduces power supply stress by 50%
-Hawkins Bass Control (0-10 dB bass boost at 15-4000 Hz)
-Trident amplifier power topology
-4 channel operation
-Vortex induction fan thermor management
-Ultra-low ESR capacitors ensure rapid power delivery for dynamic peaks
-Harmonic Bass Alignment produces tighter, clean bass
-Rail stabilization protection circuitry
-Balanced line inputs for highest noise rejection
-Triple Darlington output circuitry
-BIP (Bias Input Protection)
-Heavy duty aluminum alloy heatsink for extreme heat dissipation
-Gold-plated RCA level inputs
-Gold-plated screw terminals
-Tri-mode operation
-Variable high-pass filter (15-4000 Hz, 12 dB/octave)
-Variable low-pass filter (50-4000 Hz, 12 dB/octave)
-Bass Boost (30-80 Hz, 12 dB/octave)
-Frequency response: 10-50,000 Hz
-THD (Total Harmonic Distortion): 0.02%
-Signal-to-noise ratio: 115dB
-Input Sensitivity: 0.2-9 volts
-Damping factor: >200
-Dimensions: 15-15/16"L x 9-7/8"W x 2-1/8"H
$200 shipped
Tracking info provided when shipped.
Above^^^
Specs:
-RMS Power Rating:
-Tri-mode operation
$200 shipped
