FS: Soundstream Reference 4.400
  • 1
eg9
Above^^^
Very clean, great sound but found another amp so don't need this one. Amp is in excellent/mint condition and works 100%. Definitely underrated RMS power ratings and great old school style SQ amp!
Specs:
-----------Soundstream Reference Series 4-Channel Class A/B Car Amplifier(4.400)
-RMS Power Rating:
4 ohms: 70 watts x 4 chan.
2 ohms: 100 watts x 4 chan.
Bridged, 4 ohms: 200 watts x 2 chan.
-MOSFET power supply
-RUBI (Rapid-Use Branched Impulse) proprietary power supply technology
-STACT (Stabilized Apex Current Technology) reduces power supply stress by 50%
-Hawkins Bass Control (0-10 dB bass boost at 15-4000 Hz)
-Trident amplifier power topology
-4 channel operation
-Vortex induction fan thermor management
-Ultra-low ESR capacitors ensure rapid power delivery for dynamic peaks
-Harmonic Bass Alignment produces tighter, clean bass
-Rail stabilization protection circuitry
-Balanced line inputs for highest noise rejection
-Triple Darlington output circuitry
-BIP (Bias Input Protection)
-Heavy duty aluminum alloy heatsink for extreme heat dissipation
-Gold-plated RCA level inputs
-Gold-plated screw terminals
-Tri-mode operation
-Variable high-pass filter (15-4000 Hz, 12 dB/octave)
-Variable low-pass filter (50-4000 Hz, 12 dB/octave)
-Bass Boost (30-80 Hz, 12 dB/octave)
-Frequency response: 10-50,000 Hz
-THD (Total Harmonic Distortion): 0.02%
-Signal-to-noise ratio: 115dB
-Input Sensitivity: 0.2-9 volts
-Damping factor: >200
-Dimensions: 15-15/16"L x 9-7/8"W x 2-1/8"H
$200 shipped
Tracking info provided when shipped.
Anything 2 channel around 400 rms x 2 @ 2/4 ohms?
OS or new...........prefer something minty!
Could add cash or add other amps as trades if needed, have plenty to trade!
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Hello I have the soundstream bx 108z and just recently the remote wier came out of the power connector so I put it back in and then noticed that...
eg9
eg9
Winston-Salem, NC
eg9
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
