SOLD FS: NEW Critical Mass UL12
bones22
in my house
(NEW) Critical Mass UL12
$575 shipped in the 48
RMS Power handling: 2500 Watts (undistorted power)
Peak Power handling: 5000 Watts
Recommended Box Volume: 1.2 cuft. (Sealed)
Weight: 16.6 lbs
Motor Type: Dual Gap / Internal NEO Magnet
Voice Coil Type: Ultra-High Temp Dual Coil (Made in the USA)
Voice Coil Diameter: 3”
Voice Coil Impedance: 1.5 ohm nominal per coil
Xmax (one-way linear excursion): 36 mm (3” peak-to-peak)
Maximum Excursion (one way): 46 mm (Almost 4” peak-to-peak)
Sensitivity: 96.7 db (2.83V / 1m) (coils in parallel)
Fs (Klipple-LSI): 31 Hz
Qts (Klipple-LSI): 0.81
Vas (Klipple-LSI): 47.7 Liters
i will get up to date pics if anyone wants them.
you can see there are some very small scuffs on the bottom of the motor from when i was going to put them in my truck. never got around to it though.
coils both read 1.6ohm
the damage to the box that i have for this one since i used the other box to ship one.
i will be adding plenty of extra packaging to insure the sub gets there in 1 piece. i will also get some make sure the seam of the box is glued back together well.
The ul12 sub is the most musical sub that has every been built!! PERIOD!!! They can get loud and when they get loud they still sound fantastic. I have owned several of them. If it wasnt for the fact that my daily driver was rear ended, I would still have mine. If you would rate a sub musically, I would give it a 9.8 out of 10. How loud and clear they can get, I would rate it 9.5 out of 10. They are just the baddest sounding sub in the world!!!
and the have pixie dust:laugh:
Loudman in on the right track, they are very nice sounding and get freaking loud doing it. it is arguable if they are the tops musically, but I don't think anyone can argue the fact that they are among the front runners for sure.
Personally my favorite sub, I just wish Critical Mass would get a clue as far a customer service and care. Seriously a recone for a UL12 is $1200:eek: With that being said, who in the hell would want to drive them with 2Kw or more? I personally think when you send it in to them for a recone, they simply send you one in replacement.
bones22
bones22
in my house
kmanian
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
