bones22 5,000+ posts
(NEW) Critical Mass UL12
$575 shipped in the 48
RMS Power handling: 2500 Watts (undistorted power)
Peak Power handling: 5000 Watts
Recommended Box Volume: 1.2 cuft. (Sealed)
Weight: 16.6 lbs
Motor Type: Dual Gap / Internal NEO Magnet
Voice Coil Type: Ultra-High Temp Dual Coil (Made in the USA)
Voice Coil Diameter: 3”
Voice Coil Impedance: 1.5 ohm nominal per coil
Xmax (one-way linear excursion): 36 mm (3” peak-to-peak)
Maximum Excursion (one way): 46 mm (Almost 4” peak-to-peak)
Sensitivity: 96.7 db (2.83V / 1m) (coils in parallel)
Fs (Klipple-LSI): 31 Hz
Qts (Klipple-LSI): 0.81
Vas (Klipple-LSI): 47.7 Liters
i will get up to date pics if anyone wants them.
you can see there are some very small scuffs on the bottom of the motor from when i was going to put them in my truck. never got around to it though.
coils both read 1.6ohm
the damage to the box that i have for this one since i used the other box to ship one.
i will be adding plenty of extra packaging to insure the sub gets there in 1 piece. i will also get some make sure the seam of the box is glued back together well.
Weight: 16.6 lbs
