FS: Kicker ZX200.4/150.2/250.2 and Alpine MRA-F350
  • 4
Fast1one
California
Kicker ZX200.4, 150.2 and 250.2. Also an Alpine MRA-F350 5 channel theater amp
NOTE: I am only looking to sell the KICKER amps as a package deal! Please don't contact me otherwise unless you can find additional buyers //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Kicker 06ZX200.4: Kicker ZX200.4 (06zx2004) - 4 Channel Amplifier | Four Channel Amp - Sonic Electronix
4-Channel ZX-Series Power AmplifierLow Impedance Operation
SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
MOSFET Power Supply
KickBass: 0-12 dB @ 40 Hz
Built-In Electronic Crossover: 12 dB High or Low-Pass operation (80 Hz)
High & Low level inputs
Custom tooled gold plated connectors
SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
Cast Aluminum EndKaps
RMS Power Ratings:
35 watts x 4 chan. @ 4 ohms
50 watts x 4 chan. @ 2 ohms
100 watts x 2 chan. @ 4 ohms
Input gain control: Low Level (125mV - 5V), High Level (250mV - 10V)
Dimensions: 10-1/4"L x 9-5/8"W x 2-1/8"H
Authorized Internet Dealer
2-Year Manufacturer's Warranty
Kicker 06ZX150.2: Kicker ZX150.2 (06zx1502) - 2-Channel Car Amplifier Power Amp - Sonic Electronix
2-Channel ZX-Series Power AmplifierLow Impedance Operation
MOSFET Power Supply
KickBass: 0-18 dB @ 45 Hz
Built-In Variable Crossover: 12 dB High or Low-Pass operation (50-200 Hz)
PAST (PRE Amp Signal Transfer) Output RCA jacks
Cast aluminum EndKaps
RMS Power Ratings:
60 watts x 2 chan. @ 4 ohms
75 watts x 2 chan. @ 2 ohms
150 watts x 1 chan. @ 4 ohms
Input gain control: Low Level (170mV - 5V), High Level (340mV - 10V)
Dimensions: 12-3/4" L x 10-1/8" W x 2.5" H
8-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
2-year Manufacturer's warranty
Kicker 08ZX250.2: Kicker 08ZX250.2 (08zx2502) - 2-Channel Car Amplifier Power Amp - Sonic Electronix
ZX Series 2-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 85 watts x 2 chan.
2 ohms: 125 watts x 2 chan.
Bridged, 4 ohms: 250 watts x 1 chan.
Max power output: 250 watts x 2 chan.
MOSFET power supply
Remote bass level input (remote level control sold separately)
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
Eliminates unwanted noise in a system
Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
Bridgeable operation
Speaker-level inputs compatible (switchable) through RCA connection, Kicker 09ZISL required and sold separately
Preamp RCA outputs
Automatic turn on modes: remote, DC offset, or signal sense
Thermal, voltage, and short circuit protection circuitry
Variable high-pass filter (50-200 Hz, 12 dB/octave)
Variable low-pass filter (50-200 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-20000 Hz
Dimensions: 13-1/2"L x 9-5/8"W x 2-1/8"H
Alpine MRA-F350:Alpine MRA-F350 5-channel Digital Theater car amplifier 50 watts RMS x 5 at Crutchfield.com
5-channel Digital Theater amplifier50 watts RMS x 5 at 4 ohms
Dolby Digital, DTS, and Dolby Pro Logic II processing built-in
optical digital input (requires optical cable)
all amplifier functions controlled by touchscreen of your compatible Alpine receiver (no built-in controls)
connects to compatible Alpine navigation systems, including:
IVA-D100, IVA-D105, IVA-D106, IVA-D300, IVA-D310, IVA-D900, IVA-D901, IVA-W200, IVA-W205, IVA-W505, DVA-9860, DVA-9861 and DVA-9965.
MOSFET power supply
CEA-2006 compliant
Bass Engine® features:
variable center-channel high-pass crossover (20-400 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
variable front left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
variable rear left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
sub channel preamp output (20-200 Hz low-pass filter, 6, 12, 18, or 24 dB/octave)
variable subsonic filter (20-50 Hz in 1/6 octave steps, 6/12/18/24 dB per octave)
subwoofer phase control (0/180 degrees)
time correction adjustment (0-20 mSec in 0.1 mSec increments)
17-band parametric EQ (five bands for front, rear, and center, two bands for sub channel)
STAR Topology (minimizes internal noise and prevents ground interference)
detachable front cover
blue power LED
fuse rating: 20A x 2
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
13-3/4"W x 2-1/4"H x 9-9/16"D
All amplifiers are in great cosmetic condition, with little to no scratches. Work flawless and have been used by me personally for about 6 months. Only thinking about selling because I have my eye on something bigger //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif These would be GREAT for a two way setup by bridging the four channel for the midwoofer like I did. Additionally, you could run a lower power three way setup using the zx200.4 for the tweeters and midrange and the zx150.2 for the midbass. Lots of flexibility here and a relatively small footprint so you can hide them where you wish.
The 08ZX250.2 was purchased brand new by me. The other amplifiers were purchased lightly used and are nearly as new. Unfortunately I don't have original boxes and documentation. I do remember that the 250.2 had a birthsheet of 310 watts though :p
The Alpine MRA-F350 was purchased new by me. I have everything BUT the Ai-Net cable because it was a little kinked and I didn't feel comfortable including it. Flawless condition.
$250 + Shipping/fees for all three Kickers, or best offer. Definitely negotiable.
$100 + Shipping/Fees for the Alpine OBO
Ship via UPS at buyers expense. Paypal or USPS money order ONLY
Bad picture angle time! These are currently installed behind my backseat with the subwoofer bolted in the trunk, making it a bit difficult to reach //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif If someone is truly interested, I can unbolt the box and take some better pictures.
ZX150.2:
ZX250.2:
ZX200.4:
Group Shot:
Alpine MRA-F350:
More of the Alpine at: For Sale August 2010 - a set on Flickr
is the patch cable kinked at a connector? do you know how much a new cable will cost?
I threw it out when I pulled the amp from my car. It had one major kink/tear and overall it was just ugly. Ai-Net cables on ebay are cheap and will work just fine, there's nothing special about them //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif For example: ALPINE Ai-NET DIN DATA CABLE NEW - eBay (item 190456772783 end time Feb-11-11 18:44:12 PST)
Willing to split now. You get the better deal by just buying all three though //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ZX250.2: $90 +shipping
ZX200.4: $80 +shipping
ZX150.2: $70 +shipping
Total: $240 + Shipping, so if you buy all three you get $40 dollars off //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I will also entertain offers for two.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
918
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Fast1one
Fast1one
California
Fast1one
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
