FS: Kicker x3i 3-way active crossover
FLboy4x4
KICKER x3i is a 3-way 18dB/octave active electronic crossover with one variable low pass and two variable high pass filters. Remote control bass boost is variable to +18dB at 40Hz. Also features 24dB/octave subsonic filter, two stereo inputs, and three stereo outputs for versatile control.
Features:
•Front and Rear High Pass Crossovers - 18dB/octave, Variable Frequency (35-400Hz; 20x Multiplier Option on Front Crossover)
•Sub Low Pass Crossover - 18dB/octave, Variable Frequency (45-250Hz)
•Bass Boost Variable to +18dB at 40Hz
•Remote Level Controller
•24dB/octave Subsonic Filter
•Two Stereo Inputs with Parallel Input Option
•Three Stereo Outputs (5V rms)
•Signal-to-Noise Ratio - >100dB
$60.00 shipped
Shipping included in price
View attachment 26525279View attachment 26525280
if it was one ten foot length then I would probally do it but if not sorry. And I dont really have a need for that eq of 5 gauge sorry
795
FLboy4x4
FLboy4x4
Lehigh Acres, FL
FLboy4x4
    May 31, 2024
    May 24, 2024
