SOLD FS: Kicker KX350.2 - $115 OBO
  • 5
sundownz
Pro Seller
Supporting Vendor
11,349
North Carolina
Shipped in Continental 48 states.
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.
NO TRADES - Do not PM me with "What is the lowest you will take" - MAKE AN OFFER if you have one.
Comes with end caps and a remote.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
605
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
