FS and FT: Rockford fosgate t5002 !
  • 3
Dirtrider4eva
√\_The CaUsE__
here ya go guys. my rockford fosgate t5002 is for sale. primarily trade.
its a pretty big sized 2 channel for sure. has a great weight to it
no dents. a minor scratches. one scratch on the top body thats most noticeable.
7/10 cosmetically. i do not own the top cover. i could make a plexiglass one.
10/10 mechanically. extremely underated
rated at a measily 75x2 at 4
150x2 at 2
250x2 at 1
500x1 at 2
300x1 at 4
but its one of rockford fosgates most underated amps, Ever.
over double every rating.
they have been clamped to do
1000 at 2 ohm bridged
1300+ at 1 ohm
even stated on their website, average 110.8% underated.
and its class a/b //content.invisioncic.com/y282845/emoticons/respekt.gif.b162d148236010609fe523122efe3729.gif
i will go with 170 obo.
trades equal SMALL foot printed 2/4 channel. capable of doing 240x2 at 4 ohms, some how.
also need a mono of 2000rms+ at either .5 ohm or 2 ohm. thanks.
shipping will be negotiated
I have a new T600.2 power series w/birthsheet If I remember right it's more then your looking for per channel by a good amount I know it's 778@4ohms bridged if your interested I can locate the paper work, do you have the cover for that amp?
I'm not sure of the size of your 500.2 I know the newer amps are much smaller in size then the older models I also have a T400.2 but don't know the actual output of that one but its smaller then the 600 (sorry skipped over the part that said no cover)
no problem. its roughly 17 wide by 16 tall, 2,5 inch deep.
i only have about 3 feet wide by 14 tall for mount amps. one needs to be a mono block. if you can PM me more about the t400.2, i would be tempting to work something out. along with a pic
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Dirtrider4eva
√\_The CaUsE__
Dirtrider4eva
Milwaukee, WI
Dirtrider4eva
