Frozen Cone?
sk8erboyla2004
La
So my subwoofer Cerwin Vega 15" DVC 2 just cut off one day. Today I pull out the box check the voice coil..fine no burns or smell, checked the spiders perfectly in tact however the cone is like frozen solid it can not be pushed in by hand gently of course I used to be able to so wth?
It has to be one of two things...I would think anyways. If you did not run it really hard and lock it up then the motor must have shifted pinching the coil.Is it worth fixing?? that is up to you.Might be a recone.
Motor shifted, or the voice coil unwound. Did you check the coils with a DMM, or are you just assuming the coils are okay..? If the coil unwound in the gap, it would likely seem 'frozen'.
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
850
sk8erboyla2004
sk8erboyla2004
La
x2o
