afearlesshunter
As the title says, Im planning to run my first HO alt and Battery bank so I have a few questions. Currently I have my big three done with 1/0 welding cable fused at 300 amps between the alt and my battery (no rear bat.) and have 1 run of 1/0 back to my 1500 fused at 150 right before the amp. like so..
Anyways, I was looking at running a singer 320 amp alt, undecided front batt. and 4-6 AutoCraft Platinum AGM H8 batteries (95ah) in the rear. powering 4 of the Crescendo S1500's. I would like to use the same 1/0 welding cable because I have so much of it (rated at 350 amps max).
How many runs should be between the front and the rear batts?
I assume I should run two 1/0 fused at atleast 175 each between the alt and the front batt?
Number of grounds?
Any help is appreciated, been wanting to do this wall for almost a year now and finally getting to the planing..
Number of grounds?
