few questions about my new sub
Camaro_man
Okay...
My system is finally complete...took around 2 months but its done now. I have been using a Type R pushed by a Viper D600 giving it 600rms. I now have a dual amp setup, both Viper D600's and I also have another type R. So I have an amp for each sub. Everything is working and stuff, but i've had a single Type R now for over a month and I was really happy with it, but I got my new type R today and when they're both hooked up, it's like poo. First of all its not really any louder than my single Type R set-up, 2nd of all..once it gets past a certain volume the bass starts to sound like ****...almost like its trying to come through my doors instead of the subs. I also notice one sub (the new sub) is working harder than the other even though I have the amps tuned to the exact same setting.
Maybe the sub just needs to get broken in?
No the sub dont need broke in? You should only gain about 3 dee bee with the other sub hooked up. As far as it sounding like crud you might have too upgrade your wiring. Are they starving for power?
make sure you have the - & + wires connected right //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Okay, i fooled around with this a little bit. The + and - werent crossed. Everything is connected right. I noticed I did have a loose piece of trim right above the sub so maybe some of it was just that thing slapping around. New sub is stil making a slapping/popping sound at high volume. Other sub sounds great.
sounds like you ****ed up your new sub:crap:
Ok, the subs look fine. I switched them out and it seemed to help, but the subs still wont get loud without sounding like crap. What if they are cancelling each other out? How do I fix that?
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
I found this, can it be done with snapon modis ultra scanner which i have...
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
391
Camaro_man
Camaro_man
East Tennessee
Camaro_man
    May 16, 2024
    May 16, 2024
