Faulty speaker keeps cutting off
  • 2
Maorswan
CarAudio.com Newbie
Israel
I have a pair of Vibe midbasses, half a year ago one of them started cutting off randomaly. At first it was once in a month, then it became more frequent. I checked the wires, the amp, everything. There's no known reason. It could work perfectly for a few days, then cut off, then cut off again for 2 minutes or on-off every 2 seconds, driving, on parking, doesn't matter, something is wrong with the speaker and I wanna know what.
It has 3 states:
Working and heavily vibrating
Not working but you can still feel a very slight vibrating
Not working and completely dead
Any thoughts? Thank you.
It has 3 states:
Break it down. The only way speakers get sound is from a signal wire. Start at the speaker terminals.
Behind the terminals going to the voice coil. Are the wires loose behind the connections?
Inspect the connectors themselves. Are they loose or damaged.
Push the cone in. Is there any scratching? If the speakers check out, follow the speaker wires.
Check any junction where the wires bend or come in contact with a hard surface. Are the wires covers broken? Are any parts of the wires exposed? If the wires check out, proceed to the connections on the amp.
Are the connections clean and tight at the amp? If so the following could be the issues:
RCA cables faulty - Check the same way you did for the speaker wires.
Amp faulty - Run a new short length of speaker wire to a different "test" speaker with the speaker unmounted and see if it faults.
Head unit faulty - No suggestions.
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
563
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
476
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
639
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
548
Maorswan
CarAudio.com Newbie
Maorswan
Israel
ThxOne
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
