SOLD factory second deka 9A31's $100+ shippong each
dbeez
crestwood,ky
Specs listed below should be getting around 15 will have them by friday these go fast so order yours now to ensure.you get one.
Group Size 31 (3/8" Stud)
Chemistry AGM
Cold Cranking Amps 800
Cranking Amps 1000
Reserve Capacity 190
Amp Hour Rate 100
Dimensions:
Length 13"
Width 6 3/4"
Height 9 1/2"
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
dbeez
dbeez
crestwood,ky
dbeez
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
