Factory Radio Subs
  • 2
most just get an Audio Control LC2i to snag signals from the two rear 6x9 then feed the signal (with auto turn-on remote) to an amp/sub combo.  run dedicated power wire to the battery with proper fusing, ground to the chassis, and keep your install neat and tidy (follow factory wiring).
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
774
Two ways to go about it. First, the easy way- Next, the budget but more involved way- On the second one, you buy the harness to install an...
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
camry2007
camry2007
keep_hope_alive
    May 31, 2024
    May 24, 2024
