SOLD F/S Rockford Fosgate CRAZY GOOD DEAL
splmegavan
dayville
i am selling my rockford T1000bd this amp is very underrated, it will put out 1596 watts at 1 ohm i have the birthsheet to prove it. im asking only 225.00 shipped for the amp. i have the original box, birthsheet, bass knob, and bd sync cable to strap 2 of them together if you want. this amp does not draw alot of voltage so it will work with most eleectrical systems, it has a built in 150 anl fuse and has built in fans. it in great shape as you see, its got lil dust on it an some minor scratches it cleans up nicely, i run it as an everyday amp and the thing slamsmy 4 kicker 15s if interested message me
Details:
**1000 Watt RMS Class BD Amplifier RMS Power Ratings: **500 watts RMS x 1 at 4 ohms **750 watts RMS x 1 at 2 ohms **1,000 watts RMS x 1 at 1 ohm **Para-Punch bass EQ (0-18 dB with variable center frequency between 35-70 Hz) with wired remote control **MEHSA- High Performance Thermal management design for bigger power with more consistent thermal stabiity **MOSFET power supplies and outputs **TOPAZ - Circuit for eliminating engine noise **NOMAD - Advanced short circuti and power protection **MasterSync - allows one amplifier to manipulate another amplifier's gain, EQ, **Infrasonic and crossover controls **PowerSync - Allows bd series amplifiers to be "strapped" together to create one massive power combination **variable low-pass filter (32-250 Hz, 24 dB/octave) **Infrasonic filter: 12dB/oct Butterworth alignment protects the amp from unwanted ulta-low frequency information, increasing the usable power output and reliability **RCA Preamp Outputs **Phase switch: 0 - 180 degrees **Cast aluminium heatsinks - allows more power into a smaller heatsink be allowing engineers to localize heat in specific areas **3-Stage Variable forced convection - heatsink design that keeps the amp's internal comonents cool **1/0 AWG power and ground connections with internal ANL fusing **Dimensions: 18" L x 12.8" W x 2.66" H **CEA-2006 Compliant **Amplifier Class BD **Number of Channels 1 - Mono **RMS Power (4 ohms) 500 watts x 1 channel **RMS Power (2 ohms) 750 watts x 1 channel **RMS Power (1 ohm) 1000 watts x 1 channel **Bridged RMS Power N/A **Peak Power Output N/A **Minimum Impedance Unbridged 1 ohm **Minimum Impedance Bridged Not Bridgeable ohms **THD at Rated RMS Power N/A **Speaker Level Inputs No **Preamp Outputs Yes - 1 pair **Built-in Crossover Low-pass (LP) **High-Pass Crossover Frequency N/A **Low-Pass Crossover Frequency 32 - 250 Hz **Subsonic Filter 28 Hz **Signal-to-Noise Ratio N/A **Channel Separation N/A **Bass Boost 0 - 18 dB **Bass/Gain Remote Yes **Fan Cooled Yes **Fuse Rating 150A x 1
[/img]
[/img]
K this is a must sell this week Youll never see a price like this for one of these amaing amps like i said before and in the pics i have original birthsheet, box, and the bass knob, the amp is in awesome condition 150 bucks shipped get it , like i said this is a must sell this week message me if interested
k well i do have an ebay account as well i have perfect shipping and rating. and no bad reviews, im not looking to screw anyone like i said its a must sell once i recieve the money the amp will be shipped out
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
splmegavan
splmegavan
dayville
matrxx dude
    May 31, 2024
    May 24, 2024
