Escalade guys...i have a question.
  • 2
billabongcr
Yep
7,140
Florida
I had a thread a few weeks ago about putting my system in but was afraid of all the electronics, so I decided not to do a build. But, what if I replace the stock woofer and amp with aftermarkets of the same impedance and upgrade the factory wiring? Would it still be compatable with the Bose system and all electronics work correctly?!
And I want to say the stock woofer is a 10? or an 8? And where is it located? Under the center console upfront or under the dash?
Thanks in advance
After reading your post, I agree, i wouldn't be comfortable tinkering with electronics if i were you, either.
most factory sub locations are in the cargo area, check there homie.
nah its def not in the cargo area. it bumps from the front dash area. my best guess would be under the middle of the dash where the center console meets up to it, as I imagine theres alot of room in that area. i just havent had time with my work schedule to look around.
Me too and then I have to paddle anywhere I want to go.
6
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
those center spots shine out pretty far enabling me to see well on the dark highways.
22
3K
billabongcr
Yep
billabongcr
Florida
billabongcr
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
