Engine swap help
no, if i am understanding your question right. u can't rum a d-series tranny with a b-series motor. i think thats what your asking.
the engine will plop right in though, just make sure to get one with the tranny on it aready. And if you have the cash.. spring for a type r tranny.. better gear ratios and a limited slip.
Pimp ****, type r trannys now...does it add HP and come with already installed neons?
the d series and b seires will not be interchangeable, but the motor will bolt in the same motor mounts....you will also need an axel from a del sol and an accord if i can remeber correctly...
actually, yes it does in a way add horsepower.........this is because the shorter gear ratios which obviously take less time to get to the next gear successfully. and yes they do come with neons pre-installed. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
The only way a transmission would "add" horsepower would be if it were more efficient (lighter gears, less internal friction, etc.) ... But that wouldn't really add power, that would just reduce the drivetrain losses ... Sort of like using a lighter flywheel ... You'll see a gain at the wheels, but the actual amount of power the engine makes will remain unchanged ...
Also, the transmission may not necessarily be suited to the engine's power curve ...
thats why i said "in a way" //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
3K
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
3K
btnhfan
Hail to the King Baby!!!!
btnhfan
CT/ GA Tech, Atlanta
95RAM
Decebal
    Jun 10, 2024
