Engine Noise????
  • 2
smrtnez
CarAudio.com Newbie
I've got an engine whine with the rpms kind of deal. I'm going to try to trouble shoot it and was wondering if anyone might have some input. The one thing that stands out is the noise is coming from the front left speaker only. And that speaker is not working. But sometimes that FL speaker comes on and when it does the whine noise is gone. So is it just maybe the speaker failing? Or is it a result of another issue causing the whine and speaker to not work?
Here is my info: 2007 Silverado Ext. Cab, Kenwood head unit, Kenwood 6.5 in the front doors, Pioneer 6.5 in the back doors running off an Alpine 4 channel amp, and I have two 8" subs under the back seat and a Kicker amp running those. I put all this in a bout a year ago and all sounded fine until bout a month ago.
I wasn't sure if the fact it 's only coming from the one speaker might be a factor that someone else can relate to.
Thanks guys, any input would be appreciated.
Try checking all the RCA cables. It sounds as if your amp still sends power to the speaker while a cable is not inserted, hence the RPM whine.
Yes, I believe your right, I tried another speaker and still the same, so I unplugged both rca's for the front speakers, and the rear speakers are fine no noise, so I unplugged the rear rca's and plugged them to the front, all good. So I ordered new rca cables for both the front and back, this time I spent more $ on them. I should of did that the first time.
Thanks for your input, much appreciated....
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
3K
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
3K
smrtnez
CarAudio.com Newbie
smrtnez
Southern California
smrtnez
Decebal
    Jun 10, 2024
