double din wiring
the only thing that could possibly be different would be.
1. If you want need to ground a parking break wire for DVD play back
2. Navigation ( which your new radio doesn't have)
theres tons of modules to bypass that brake switch on ebay. or you could just wire it to the brake switch. i chose that route. just because i feel like itll get me in trouble otherwise and i dont really need to watch a movie while going 80 on the highway lol.
Wow thnx i have a single din sound stream an it works fine on the start up but fOr sum reason it only shows video to the other screens wen I play the video an not while I cruise through the main menu any ideas ???
try the toggle on the brake ground wire .put the toggle in between the deck and ground point ,just switch it on and off.it works on soundstream decks too
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
Look at the JVC brand. I have an older unit with a removable face plate. Model KW-AV61BT. Contact Crutchfield.com support for some current...
Alpine HALO has a very nice display but lack remote control which I really miss more than I thought I would. I've been really into the Sony...
26
4K
mikemct15
mikemct15
Rosalind, AB
mylows10
    May 31, 2024
    May 24, 2024
