Doors still sag?! WTF
ThatChevyGuy
sue me, its a ford.
13,454
26
Georgia
I replaced my beat to **** doors on my 91 chevy 1500 today with some straight doors, i went and bought new bushings and door pins and installed the doors. After all that work, the motherf'ers still sag and you have to shut them with force. What the hell?!
its nothing to see its flat black with blue doors lol.
When the doors are open and you lift up on them, there is no play like it was, but they go up about an inch or an inch and half when you shut them and the same (drop) when you open them. Im thinking the only thing it could be is the hinges on the body are bent at an angle like this / causing the doors to sag at the ends?
i assumed they wouldnt be bent as thick as they are. **** i guess i have to take the doors BACK off and see. Thats got to be the problem, they didnt sag on the donor truck
mine sag too //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i have about 40 pounds of deadener/mlv in each door though so at least they are quiet //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
you can adjust the striker, does the end of it look like a torx? if so you can loosen it and move it up or down about a 1/4 inch each way
edit- ill be on aim for a while if you wanna hit me up
Yeach check out that door sticker/check first. See if it being rubbed on to much. Even your latch part will show signs of it being off.
Those are super nice!! I may have to go that route if by chance they don't fit.
19
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
added a 32AH bank to my system...... Cot damn! Now we rockin. Voltage staying above 13 wide open!! Just thought I'd update.
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
audioatg
    May 18, 2024
    May 16, 2024
