door trigger isolation
  • 3
desitdt
Hey there i have a 2000 ford explorer and im trying to isolate the door triggers for the alarm activation.
I have followed these steps but it still does not work:
The BCM is to the left of the radio. Remove the radio and then the two 8mm screws. The dash snaps right off. You can get lights and all triggers right there. I don't like the double diode isolation. I isolate all 5 triggers and then use a relay to trigger the alarm.
5 triggers to 85
fused 12v to 86
Ground 87
87a not used
30 to green wire on the alarm
Ive wired everything this way but it doesnt make sence.
so when any of the door triggers pulls to ground, the relay contact closes and the alarm wire is pulled to ground. that is how it's wired.
can you hear the relay click when you open the door? are you sure the doors are negative trigger?
are you sure the alarm wire you connected wants to see ground. some alarms can have positive or negative trigger doors, and some have separate wires for each one.
Resistors don't have polarity so you can't wire them backwards. Is resistors a typo? Did you mean the relay coil? That doesn't have polarity either. The door triggers may or may not have polarity depending on the trigger. Negative trigger switches just have one wire connection since the housing is grounded to the car body. Positive triggers have two connections that are isolated from the chassis.
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
502
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
757
Tons of options in that budget, including the cost of installation,
10
desitdt
desitdt
Tallahassee, Fl
keep_hope_alive
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
