Do I need a Hi Lo Converter
  • 4
connerprince
CarAudio.com Newbie
15
Irvine
I have a brand new Toyota Corolla Cross and the speakers aren't putting out enough volume. My plan is to add an amp for the speakers, maybe replace the speakers or leave factory till they blow, and add a 12" sub, possibly with its own amp or do one 5ch amp for everything. A few shops I stopped by said I need a Hi lo converter. What are y'all's thoughts on them and any recs on any good ones?
you don't want to put an amp on the factory speakers in this scenario. If you aren't changing the stock radio, find an amplifier that takes high level inputs. Or has a legit DSP inside. Depending on whether your system is amplified already or not will dictate what moves to take. Is it amplified?
as bald waldo said, amplifiers with a high level input means they already have a "loc" built in.... it just reduces voltage down to a level that wont clip and distort the signal... basically a resistor of the right value..... you CAN overpower your stock speakers about 30%, but only if its a clean signal. typically, factory speakers are only good for about 22-25watts rms. thats the same power a head unit typically puts out.... because they are built that fragile, usually means they are built more sensitive, but not always the case... many aftermarket speakers will typically put out less for the same power, but the cones are also not built for much more than the low power, so its kind of like firing 5.56 rounds out of a 22lr barrel..... if you have access to a meter, you can use a 4channel amp, from a boost box to a big 4channel and set the max voltage to the speakers by calculating what voltage it takes to reach your desired wattage rms, which can be what the speakers are rated for plus 30% and it might last for decades that way, or minutes. theres some amps that can handle 10.5v inputs, and many factory systems that send 9-10vac to the speakers. if you find those matching up, then you can wire the speaker outputs straight to a pair of rca wires to the amp "low level" inputs and turn the gain way down to match. i havent messed with the brand new yotas, but they have, in the past, been in that 9.5-10.5 range, so it mostly depends on what amp you choose. either it can take the 10.5 or less, or it cant, but has high level inputs. unless you buy an amp that doesn't meet the criteria, then you shouldnt expect to spend more than 30 for a loc, unless you fond one thats a dsp that does more than function as a pair of resistors/pots that lower the speaker level voltage.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
You can use a 2 channel one and just use RCA Y cables to go from 2 to 4 outputs Do yourself a favor and get one with a line driver built into it...
Here in the USA. I am not sure the Honda Jazz exist. Ive never heard of one or have seen one. Though it looks very familiar to a Honda Fit that we...
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
409
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
322
connerprince
CarAudio.com Newbie
connerprince
Irvine
akheathen
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
