Diamond Audio TX black TX65V 6.5" Convertible Components
  • 1
trumpet
Barry Schanz
Coaxial OR Component
NIB
The team at Diamond Audio appreciates great sound and it’s this reason that Diamond Audio has developed the new Tour speaker series. Engineered as a Tru-mount convertible speaker, flexibility and versatility cannot be any easier. A composite ABS frame design is utilized for rigidity and noise vibration cancellation. Tour speakers feature high performance graphite injected molded copolymer cones with optimized on-board crossovers. Audiophile quality sound is achieved with a 19mm aluminum dome tweeter with Ferro fluid cooling.
Tour speaker series work great in an amplified aftermarket system but can also make your OEM system sound audiophile.
Features and Specifications:
  • Power handling: 50W Nominal, 100W Max
  • Total diameter: 6.51 in. (165.4 mm)
  • Mounting diameter: 5.53 in. (140.6 mm)
  • Mounting depth: 2.32 in. (59 mm)
  • Magnet diameter: 3.40 in. (86.4 mm)
  • Convertible design: coaxial or component
  • Graphite injected molded copolymer cones
  • Optimized on-board crossovers
  • 19mm aluminum dome tweeter with Ferro fluid cooling
I also have a Diamond Audio 4-channel amp that would be perfect for these speakers plus one more pair of speakers.
$159.99 with FREE shipping(average cost is $20 to ship a set of speakers)
free ground shipping within the Continental US
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
11
A Link would be very helpful. Id be interested in taking a look at some gear
233
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
352
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
Decebal
    Jun 10, 2024
