Alpine cda 7998 and alpine 12 disc cd changer
  • 2
Polski13
MI
Alpine cda 7998 head unit
And
Alpine 12 disc cd changer
Cda 7998
8/10 cosmetically because some button lettering has slight wear, the trim ring has broken tabs. 10/10 mechanically. Unit has been bench tested for power and all face functions.
Remote, wiring harness, cage, trim ring, original manual included. I don't have the original box.
Features
FantomFace XL motorized stealth faceplate
BioLite high-resolution display
switchable green or amber button illumination
plays MP3 files on CD-R or CD-RW, plus audio CDs, CD-Rs, and CD-RWs
MaxTune SQ tuner
XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal.) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
Bass Engine Pro (5-band parametric EQ, 6-channel digital time correction, 6-position crossover with variable slope, plus subwoofer phase and level controls)
Media Xpander
CD changer controls for Alpine Ai-NET changers only
optional auxiliary input
premium-quality power supply and output capacitors
gold-plated 4-volt front, rear, and subwoofer preamp outputs
i-Personalize
clock
wireless remote
component amp(s) required — no internal amp
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
Cd changer
7/10 cosmetically because theres a slight crack in the upper right hand corner. Other than that, the changer has never been used. I never got the chance to install it.
Accessories/ hardware and screen for sliding door included.
400 obo
Buyer pays
Is the case cracked on the right side of the cd player ? would you separate the two ?
Yeah it is, you can see the crack in the pic. I may consider seperating, but it wouldn't lower my price by too much
What would the separated prices be then ?
I didnt want to seperate. But i guess ill let deck go for $330 shipped. I didnt want to go that low.
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
That’s really helpful, thanks! I’ll keep digging and see what I can find online :)
4
I'm hoping to find someone who might be able to repair this head unit. The faceplate doesn't slide out at all.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
566
Polski13
Polski13
MI
Polski13
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
