Diamond Audio TX black Tour Series TX3004 300W 4-Channel Amplifier
  • 2
trumpet
Barry Schanz
NIB
This is part of the all new line of Diamond Audio introduced last year. If you like what you see there's more where this came from. All authorized with the warranty intact.
With a punctuated all-black color scheme that radiates elegance, power, and beauty, the new Tour series amplifiers not only look good, they also deliver on performance. The balance of power and control comes from within where audiophile grade components fill the amplifiers mil-spec multi-layer circuit board that produces exceptionally clean signal and massive power.
Tour amplifier models utilize Class GH high efficiency SQ design as well as superior Class AB topology for unrivaled sound quality amplification. A continuously variable SQ 24dB/octave crossover and infrasonic filter provides greater control on the Tour amplifiers with Class GH topology while a continuously variable 12dB/octave HP/LP filter accommodates the Tour amplifiers utilizing Class AB topology.
  • Topology: Class AB
  • Power: 50 x 4 @ 4 Ohms, 75 x 4 @ 2 Ohms, 150 x 2 @ 4 Ohms (bridged)
  • Smart protect thermal power protection
  • Continuously variable SQ 12dB/octave crossover
  • Signal to Noise: >90 dBA (20 to 250Hz)
  • Min/Max Voltage Requirements: 9V to 15.5V DC
  • Crossover Configuration: Switchable(Off/HP/LP)
$299.95 shipped
UPS ground shipping to the Continental US
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
171
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
    May 31, 2024
    May 24, 2024
