Diamond Audio D5 600.2 - Powerful, SQ Amp - 900+ RMS @ 4Ohms - $170 Shipped
Zellner
RE SE 10 D2
831
Ga
Diamond Audio D5 600.2 In amazing condition as shown. 90A fusing. This is a quality piece of equipment. It is THE most powerful / clean amp Ive ever owned for its ratings, makes quick work of my old school RE SE 10 which I, and several others have run at 800RMS daily before.
Condition is shown in pictures. Rated at 600x1 @ 4ohms and 300x2 @ 2ohm extremely underrated when on decent electrical....
RMS Output Power Ratings " "
150W x 2 @ 4 ohm Stereo
300W x 2 @ 2 ohm Stereo
600W x 1 Bridged @ 4 Ohms
Freq Response: 10Hz-50KHz
Signal-to-Noise Ratio: 102dB
THD: 0.03%
Channel Separation: 80dB
ACTUAL TESTED SPECS ON THIS AMP:
$170 Shipped
Free, I'll cover it.
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
173
Zellner
RE SE 10 D2
Zellner
Ga
Zellner
    May 31, 2024
    May 24, 2024
