Cutt-off Frequency question
  • 3
soul
I have a question will I damage my subs if I set the cutt-off frequency high? I have 2 15" Avalanches the cutt-off frequency in the Pioneer P80MP head unit ranges from, 50-80-125Hz and the limit I believe is +6 in each frequency. I notice I get more bass if I put it in the 80 +6 or125 +6 Hz as opposed to 50Hz. I just dont want to blow or damage my subs. Any help will be appreciated.
Thanks,
Danny
Nope , nothing wrong with doing that if you like how it sounds , I have my subs set at 80Hz and my midbass's 80 to 300Hz and mid-tweeter 300Hz and up . Before I got the mid bass's I used to run my subs up too 120Hz .
I run my subs at 63hz cutoff, with 12 db rolloff. That sounds the best to me. If you have comps that can handle it, set them 70-90 if you can.
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
778
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
966
soul
soul
LA's Finest
Kickerkitty
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
