Curious About the Best Way to Wire Two Subs
  • 2
JasoninDLH
Jason Was Here
109
31
MN
I have two 2 ohm SVC subs. One is on the passenger wheel well and the other is on the driver side and I’ll power both with a 1 ohm amp. Can I bring both wires from the subs and connect directly to the amp to present a 1 ohm load or do I need to connect it like this (I had two amps powering each sub separately that I’m replacing so the wiring is all setup so I prefer doing it the first way):
You can wire them like this or you can wire them both independently and connect them/wire them together at the amp's terminals.
Great, thanks!
I will keep the independent runs (since it’s all wired like this already) and I’m assuming I will have to twist both positives and both negatives together and connect each twisted pair into the amp connection labeled “1 Ohm” which is A- and B+….
Maybe one day I’ll completely figure this wiring out. But for now I need help.
Yeah you have it.
That is 4 inputs / 4 terminals for one channel. They just doubled the inputs to make wiring easier, for the exact reason of what you are doing. Usually they are next to each other + + - -, but it looks like yours is the other way. I would double check the manual. Instead of wiring them together and stuffing under one screw, you can just wire them straight into that. (One channel with 2 pos and 2 neg terminals).
My main car the last 10 years or so, it's a 1995. It has gotten more rusty since I took these photos. I planned on doing the body work / painting...
32
8K
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
700
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
602
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
778
JasoninDLH
Jason Was Here
JasoninDLH
MN
JasoninDLH
Decebal
    Jun 10, 2024
