Curious About the Best Way to Wire Two Subs
  • 2
JasoninDLH
Jason Was Here
109
31
MN
I have two 2 ohm SVC subs. One is on the passenger wheel well and the other is on the driver side and I’ll power both with a 1 ohm amp. Can I bring both wires from the subs and connect directly to the amp to present a 1 ohm load or do I need to connect it like this (I had two amps powering each sub separately that I’m replacing so the wiring is all setup so I prefer doing it the first way):
You can wire them like this or you can wire them both independently and connect them/wire them together at the amp's terminals.
Great, thanks!
I will keep the independent runs (since it’s all wired like this already) and I’m assuming I will have to twist both positives and both negatives together and connect each twisted pair into the amp connection labeled “1 Ohm” which is A- and B+….
Maybe one day I’ll completely figure this wiring out. But for now I need help.
Yeah you have it.
That is 4 inputs / 4 terminals for one channel. They just doubled the inputs to make wiring easier, for the exact reason of what you are doing. Usually they are next to each other + + - -, but it looks like yours is the other way. I would double check the manual. Instead of wiring them together and stuffing under one screw, you can just wire them straight into that. (One channel with 2 pos and 2 neg terminals).
My main car the last 10 years or so, it's a 1995. It has gotten more rusty since I took these photos. I planned on doing the body work / painting...
32
8K
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
712
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
614
787
JasoninDLH
Jason Was Here
JasoninDLH
MN
JasoninDLH
