crossover question
  • 4
iamaaron
i'm interested in choosing individual components to create a personalized 2/3 way component setup.
i'm wondering: if i get an active crossover, will it conflict with my amplifier(s) built in crossover? mainly the cutoff frequency--if i set the cutoff for tweeters at say 2k hz on a preamp crossover, but the 4ch amp's internal crossover only goes 50-250, will the cuttoff mess up? i guess i'm just confused.
If you want to use an active crossover, you have to set your amp crossover to full range. Two different interfering cutoffs will mess up the sound. Use one or the other, not both.
You can use multiple crossovers to get the proper slope you want, but having different crossover points will almost always cause issues. As suggested above, its usually best to get a crossover that handles all your needs, and just disable the crossover on the amp(s).
Yep. It would be a little over 3 wired in series, but that’s fine.
851
id start with 80, fine tune from there good test track...
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
434
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
iamaaron
iamaaron
Cincinnati, OH
audioholic
    May 31, 2024
    May 24, 2024
