Wiring subwoofer, better way?
  • 2
JayWheezy
Hi, wanted to see what you guys thought. Going to be hooking up an idmax10, and it will be inverted in a tline. Will be wiring the sub at 2ohms, and would like to know if there's a neater/better looking way to wire the speaker wire to sub from the amp. Is there something I can use to connect the two wires going to the pos and 2 going to the neg, without just sticking the bare wire in? Or would that be the best way?
Many companies offer speaker pin connectors for speaker wires. Its simply a male pin, with a hole and setscrew to allow you to feed the wire into. Then the male pin fits into the speaker connector. Google speaker pin plugs to see what I mean.
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
987
No. Those are speaker level inputs from the subwoofer. Lower frequencies should go to the subwoofer. The other front and rear speakers carry a...
10
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
Follow the wiring diagram provided https://euphoriacaraudio.com/product/ewx6neo/#wiring
JayWheezy
JayWheezy
Cape Coral, FL
audioholic
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
