crossover input sensitivity
  • 1
noble brown
So we all know how to set the gains correctly on our amps, or we should if we've been paying attention, but little is said about setting the input and output sensitivity on active crossovers and line drivers. Could someone maybe break down the proper way to do this. A specific application is I have a active crossover and a line driver/crossover Lanzar - OPTID100 - Optidrive 7 Volt Line Driver Crossover Network w/Remote Bass Boost
Between the the first crossover and the sub amp. I know what my max clean level from the radio is and can avoid any clipping without the crossovers but with them how do I know I'm not clipping w out a scope.
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
502
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
I usually cross at 80hz And as a drummer The meaty end of a kick is 40hz..like bands such as Metallica 50hz is a U2 kick
9
noble brown
noble brown
Hermitage, pa
noble brown
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
