Concept EX-12 enclosure dilemma
  • 2
n2audio
OPTIDRIVEN
I THOUGHT I was getting a couple dvc 2's @ 850w and I could just drop one into my 2.6cf ported @ 28 enclosure and be good to go.
However, after discovering the Ebay seller I bought from is a liar I find out I have DVC 6's at 460w.
My amp is 1000 rms @ 1, 700w @ 2 ohms and under-rated.
I'm now trying to figure out what to do with my enclosure. I don't want to rebuild a box right now, even if I did I wouldn't want it much bigger...
I can make a new baffle and go with the pair sealed wired at 1.3, but winISD tells me I'll have an f3 of about 50hz which would take all the fun out of it for me.
Or I can go ported, and using some poly-fill (according to this: http://www.diysubwoofers.org/talkshop/messages/41415.htm) get an equiv volume of about 3.6cf, and tune to 32-34 which would move the f3 down to about 32.
Anyone ever depended on the properties of poly-fill so directly? Did it work?
Other thoughts?
Subs showed up. They look unused, real nice.
Checked them on my home stereo. Both work.
Still brainstorming for my enclosure.
Current encl is a little over 3.0 gross, 2.7-2.8 net.
I can manage about 4.0 gross with a reubild //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif and about 5.6 gross with polyfill.
Winisd gives me an ideal enclosure at about 5.6 net at around 27
With a polyfill enhanced box I can get 5.3-5.4 net and tune to about 32. The plot looks real good.
Venting baffles me though. If I build two 3x3's I can get a length under 10" and not a problem on port velocity. If I go with just one, you would think a 3x6 would yield about the same results, but it's not close. It doesn't make sense to me.
But apparently nobody gives a **** about my subwoofer dilemma.
They're older. There's nothing recommended.
Concept currently has no website.
I had to hunt for a corporate email and was able to get the t/s parameters, that's all I have.
Hmmmm, let me see if I can find any of my old manuals. The recommended enclosures usually yield a pretty flat response. I have never had any regrets.
I sent an email back to the individual that gave me the t/s parameters asking for factory enclosure recommendations.
For ported I got 1.0cf at 35 (f3 @ 39) or 1.5cf at 33 (f3 @ 33).
The 1.0 just won't be low enough. Half the rap out now is in the mid 30's half the time.
According to the plots I'm getting 2.5 at around 28 looks real good.
  • Locked
The Orion Concept 97.2 was the worlds first stand alone digital 30 band 2 channel equalizer. The Orion Concept 97.2 processes all the equalization...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
639
n2audio
OPTIDRIVEN
n2audio
Lawrence, KS
n2audio
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
