Combining Power for Amps
  • 2
Glewis
I am planning out my install and want to run a single power cable from the battery to the trunk, then split into two 4 gauge cables to power a sub amp and a speaker amp. Each are rated for 4 gauge power. My thought is to use a larger fuse at the battery and then 2 individual fuses at the split in the trunk, with each fuse being rated for its individual amp. Any thoughts or experience on this setup? My main hangup is that I'm not sure what gauge cable would be good for the run from the battery or if I should just play it safe and go with 0 gauge.
I'm not familiar with Vertigo amplifiers. If they have a master-slave setting, you only need one gain. otherwise, @dragon.breath nailed it.
965
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
8
180
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
553
Glewis
Glewis
Vacaville, Ca
BCotrell
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
