Louisiana_CRX 5,000+ posts
dem shoes......
Any classic Camaro or Z/28 owners here ?..I sold my old 67 RS ..so I'm down two 2 now a 2nd and 4th generation .... I was curious to know if anyone else liked these cars as well ?
Id like to see pics of that install if you have any ..I miss my 1992 RS 25th Anniversary Heritage Edition. It was a 5-speed. It was the Camaro that I learned that you CAN flush mount a head unit in with the Metra Kit that slides and a hidden mod.
This is the best I can do. A still from a crappy video I took after I installed an Alpine in the Camaro. Behind the factory radio and on each side of the transmission hump are vents. Remove the vents but leave the vent grills on either side of the console. See the vertical vent under the radio? Remove all the ducting for those behind the radio and you can flush mount a full length single DIN radio in there with the Metra kit that has the sliding mount.Id like to see pics of that install if you have any ..
Id like to find that kit my 83 Trans AM NASCAR Pace car has that same dash layoutThis is the best I can do. A still from a crappy video I took after I installed an Alpine in the Camaro. Behind the factory radio and on each side of the transmission hump are vents. Remove the vents but leave the vent grills on either side of the console. See the vertical vent under the radio? Remove all the ducting for those behind the radio and you can flush mount a full length single DIN radio in there with the Metra kit that has the sliding mount.
It's a Metra for 82-92 I see no reason it wouldn't work for a TA. It just has to be the one with the adjustable sliding mount.Id like to find that kit my 83 Trans AM NASCAR Pace car has that same dash layout
Metra 99-4700Id like to find that kit my 83 Trans AM NASCAR Pace car has that same dash layout
Thanks..ill pick up a couple ..it should work in my 84 S10 as wellMetra 99-4700
Metra 99-4700 (met-994700) Telescoping Installation Dash Kit for
Metra 99-4700 • Telescoping Installation Dash Kit for Select 1982-up GM Vehicles Telescoping Installation Kit for Select 1982-Up GM Vehicles • Includes a new bracket system design that allows the kit to telescope in and out in any increment • Accommodates 2-Shaft DIN DIN Pullout and...
The only limiting factor in the bodies by Fisher are those vent ducts behind the radio.Thanks..ill pick up a couple ..it should work in my 84 S10 as well
I'll look at mine tomorrow..I sold my Alpine d852 out of it a while backThe only limiting factor in the bodies by Fisher are those vent ducts behind the radio.
