Car Amp question
  • 5
TLady
CarAudio.com Newbie
Texas
I have 2020 Jeep Compass and I had a 2000 watt amp that pushes a 2000 watt subwoofer.4 gauge wiring installed to hook this up. If I get all the 4 gauge wiring changed out to Zero gauge wiring, will my system have more power and higher quality afterwards?
A legitimate 2000 watt amp will draw approximately 150 amps. So you would need a minimum of 2 gauge wire to be sufficient.
45063
Like in my truck I will be running a 700 watt mono block and a 200 watt 4 channel. So the most my amps will draw is 100 amps on a 13-16 ft run 4 gauge is sufficient. But I never run my audio full blast, so they will probably never pull over 60 amps.
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
663
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
889
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
875
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
5
TLady
CarAudio.com Newbie
TLady
Texas
audiobaun
Decebal
    Jun 10, 2024
