Can my car handle these two amps?
Falloutkid90
What's up guys this is actually my first thread on here. I have a camry with a 70 or 80 amp alternator. Right now I have it running a kicker zx 300.1 for my kicker comps. I have a set of kicker ks installed but not amped right now. I was looking at a kenwood four channel amp (Kenwood KAC-8405) 60x4 at 4 ohms to run them. My question is can my alternator handle running them along with all the other basic function the alternator needs to run? I put in a new battery not to long ago btw.
I've actually been wanting to do the big 3 but its getting alittle cold out here. I do have about 20 ft of 4 gauge wire in my garage. Does the big 3 have to be done with 0 gauge? Or would 4 gauge be ok? I want to stay my stock wire is 8 gauge.
My camry set up is currently at a 100 amp draw with stock electical and knu 1/0 to the trunk. I get some voltage drops at full tilt. Anything over 120 amps with stock electral in that vehicle will require an extra battery.
Actually u should.mind.your own **** business..theres no sense is doin big 3 in 4 gauge then have to redo it in 1/0 when he wants to upgrade...i know plenty about electrical
If you dont do it in 4/0 your doing it wrong,so 1/0 is for feggies and people who are not loud
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
913
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
256
A Link would be very helpful. Id be interested in taking a look at some gear
250
687
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
Falloutkid90
Falloutkid90
Hartford, CT
audiobaun
