Can my alternator handle the system I'm about to put in?
  • 6
It might make a tiny difference, but at 80 amps the voltage isn't going to drop that much in that short of wire either way. Now if it was a 320 amp alt. then you would be looking at 4x the voltage drop in the same length of wire, which may come up to be a more noticable number.
Edit: Just for piece of mind I calculated it out. In a 4 foot run of 4 gauge copper wire with 80 amps of current the voltage will drop .07952V, and that is if he removes the original wire and only uses 4 gauge. With a 4 ft run of 0 gauge copper wire with 80 amps of current the voltage will drop .031456V.
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
I don't have one...but I check my voltage with a dmm once a week or so
12
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
tgraham09
tgraham09
Linesville, PA
Chriszle
